Partially inspired by Bob’s bridge building and by my score of some 2x2 Architectural Aluminum tube from work; I’ve begun the re-hab of the West Esca’pe lift-out bridge. First, a little history… The name Esca’pe was chosen by my son Matthew inspired by Dory’s pronunciation of Escape in Finding Nemo. There are two lift-out sections where the main line leaves (or escapes) the house. Indoors is East Esca’pe and outdoors is West Esca’pe. They were originally built about 7 years ago from CD plywood and 1x2 furring strips. The indoor bridge was changed to a folding lift-up bridge about 4 years ago. My design for the outdoor lift-out was very functional, but lacked structural integrity. It has sagged a lot over the years. Last year I attempted to remove the sag and tighten it up, but was only slightly successful. The outdoor bridge has been on the “to be fixed” list for a while. Original bridges before paint… East Esca’pe Indoor bridge…
West Esca’pe Outdoor bridge…
This weekend I took a close look at that piece of Aluminum I brought home from the scrap pile. It was long enough, and with a few passes over the table saw I was able to simulate plywood extensions that drop into the abutments at each end. Pictures of the existing bridge and progress on the new bridge will follow soon. In the mean-time, here’s the Over Engineering department’s drawing of the new bridge. I’m not aiming for a scale model, but rather something that looks a little more like a railroad bridge than the thing it’s replacing. There will be no rivets and probably no guard rails. Bridge ties and walkways are being considered…
I bought all of the Plastruct 1/8" angle the LHS had, but it’s not enough to finish the plates. I decided to use some .040 styrene from the work scraps to coat the bottom edge to simulate the bottom angle. I applied this today with 2-part epoxy. I also filled in the tube at the end where it was cut. I found that by laminating 3 sheets of 3mm PVC together and epoxying them inside the tube, I could get almost exactly the same thickness as the 1/2" ply of the original bridge. I’ll get some pictures to try and explain this better.
