The last few days have been spent making and buying additional tooling to make it easier to make these gearboxes.
Still waiting for a order of bearings that I need.
My test loco’s are as follows:
All with the gearboxes. The 1st and 4th drivers have been bushed for no lateral play.
#464 All wiring has been gutted in the loco and tender. 4.2 AH Ni-MH 24V battery, Airwire and Phoenix P=5
8 lbs of lead added and balanced between 2nd and 3rd driver.
#463 Cut stock PC board out of the tender and used B-man wiring. Loco is factory stock 4.2 AH Ni-MH 18V battery,
Airwire and Phoenix P5. 3 lbs of lead added and balanced
#453 Factory stock with a Aristo Rev board installed. 4.2 Ah Ni-MH 18V battery
All loco are wired for trailing car battery.
Gearbox in loco #463 has over 100 hrs of running on it. with the sound off you can here a little gear noise
when it pulling a grade with 2 AMS gons with 25 lbs of lead in them. On the flat and down hill, no noise.
With a 14.2 V battery and the throttle wide open on level track pulling 15 lbs in the gons, 50 seconds to
go 80 feet. Up 2% grade pulling the gons, 200 feet it took 2 minutes 6 seconds.
With this gearing, The loco stays a pretty much a constance speed on the flat in curves and on the grade.
pulling 5 AMS boxcars and a caboose.
#464 will pull 5 gons with over 100 lbs in them on the level track and 70 lbs up the 4% grade. will do some
more weight pulling with #464 and see how well a stock loco will pull on the 4% grade.
I ran #453 with my Accucraft K-28 and they ran very good together.
Rodney
