I have not been around for awhile cause I had a lot of stuff I needed to get done and I’m starting to build some live steam shays. I’m tiring to get the gears made and I will proceed with that when I figure out how to make bevel gears. As some of you know this has been a project that I have worked on for sometime. After a lot of failures, I have a prototype done and installed that works, BUT is is a little noisy. With the sound on I can just barely hear the gear noise and for me is OK. My original idea was to put a gearbox between the motor and the stock B-man gearbox. When I first tried this, the gears I was using were of 32 pitch and I couldn’t get the gearbox small enough. The next smaller pitch gear that was commercially available that I could find that was affordable was 48 pitch. The 48 pitch I felt would not have enough teeth contact being as narrow as I needed. So the search went on till I was at a buddy’s house and he had a set of 40 pitch gear cutters. I never even thought about cutting my own gears. First thing you need for gears is a blank that is the OD of the gear that you are going be cutting. The blank goes into the chuck on a indexing head or rotary table with indexing plates (I didn’t have the plates for my table so I used the degree index). The pictures I took while I was cutting got deleted so I staged some for you to see how spur gears are made
When I get the gears cut on the blanks they look like this.
Then it to the lathe to cut to length
To get the correct length I have a DRO (Digital Read Out) on the saddle of my lathe.
My gears are cut to .190 wide plus the thickness of the cutoff tool This is what I have after I get all of them cut off.
I have another fixture to drill and ream the hole in the center
So now I have the gears done the gearbox was made (didn’t take any pictures of that) I made 18 and 24 teeth gears. A 18 tooth gear gets pressed on to the motor after I take press off the worm. I make a compound gear shaft with a 18 and 24 teeth gears and then press a 24 tooth gear on the output shaft.
Press the worm onto the output shaft and it is ready to install on the stock gearbox. This is the first K-27 I bought and you can see that I added about 5 lbs of lead to it. I have a lot of running time on this engine and the extra weight has not hurt it that I can see. It pulled 20 stock (no axle bearing) Accucraft cars up my 4% grade before I added this gearbox, so I know it will only get better with it.
The compound and output shafts are running in ball bearings. The gear noise is because I used brass for the gears. I have a few sticks of Derlin that I will remake the 24 tooth gears again. With the Derlin there should not be any gear noise at all. The final ratio is about 26 to 1 When I get the Derlin gears done I will give a update on how the noise is. Then I will make about 25 gearboxes and will sell some. Rodney
