Making Redwood Lattice for My Railroad
When the lattice system was introduced to garden railroading several years ago a few of us in our club used the method to construct a small traveling layout that we could take to garden shows. But the use of plastic material didn’t hold up well and didn’t have enough support. Working in construction I consulted a wood working friend who helped me develop the method I currently use. Some of my original lattice pieces have been outside for over 10 years now and are still in good shape on my railroad. This is my method.
All of my lattice pieces are between 10 and 14 feet long and constructed on templates inside my shop. I have curved templates for diameters from 10’ up to 20’ that I use on my layout and predetermine how and where the track goes before I make up a lattice section by placing these templates on the railroad to see what I like. The templates are made out of 1/4” plywood and cut 3” wide with a centerline drawn on them. Then I mark and drill a small hole on this centerline every 6”. The holes are the location for the pegs that I attach to the template to give the shape for the lattice. The pegs are cut from 1-1/2” dia closet rod and have a hole drilled through the center for a screw.
My lattice is made from redwood. I start with a 2 x 6 piece of material with very small tight knots. I cut it into 1/4” wide strips the thickness of the board, 1-1/2” on my table saw. You will need 4 strips for every length of lattice. Then I cut 1-1/2” x 1-1/2” strips and cut them into 2” long blocks on my chop saw. You will need lots of these.
I start by placing the templates on my work bench screwed down in the desired configuration that I want with pegs screwed down every 6” on the center line. (see photo)
The first step is to attach one of the 1/4” strips to one side of the pegs using the 2” spring clamps. Leave enough room at each end for a 6” long block.
