Hello Everyone… We have just finished the redesign of our New C-10 Carrier Board, and I thought I would share these pictures with you. From the previous design we have taken all your great suggestions and ideas and added these elements to the board. We changed the layout by turning the charging circuit board horizontal, which made the board 12’’ in length by 3’’ in width. Upgraded the battery to an 18V @ 3800mah Nimh, changed the battery wire leads input to screw terminals from four prong header pins which plugged directly into the charging circuit board. Even though this photo may not show it, we lengthen the controller and sound area to give you more room. But, the most suggestions we received were to add external plug-ins for a DC power jack and a DPDT Run/Off/Charge switch so if you did not have the ability to open the side door to your box-car, you could add hook-up a 2.5 DC power jack and DPDT switch to the outside. We have added those two plug-in features with 12’’ wire leads, I will up load those additional photo’s within the next couple of days.
Soon I will have more information here on Large Scale Central, along with additional photo’s and an instruction manual that you can download from our website. We will also have this on display at the ECLSTS in York, PA coming up on the 26th, please stop by our booth and say Hi. Adding these additional features to the board has increased the price to $229.00 ea. Price includes: C-10 Carrier Board, Single Station Smart NiCd/Nimh 0-18V Charging Circuit Board, 18V 3800mah Nimh Battery-Pack, 5W 8ohm Speaker, 12’’ 2.5mm DC Power Jack with detachable quick connector, 12’’ DPDT Run/Off/Charge Switch, 1 amp desktop wall transformer, 8 nylon stand-offs and 16 2-56X 7/8 screws. Thank you for your ideas and comments, Rick Isard Cordless Renovations, LLC
