I have a enercell (radio shack) 9 volt NI-MH battery that I’m using in a engine to power an older Dallee sound system. these older systems don’t charge from the track voltage so the battery wears down over time.
The battery is inside the engine under the hood so I put a charging plug in when I was wiring it. I thought I would use a converter but now I’m second guessing the charger I have. It is an adapter with a output of 9 volt 210 mA. I’m concerned this is too much output and will cook the battery.
What should I be using to charge this battery?
