Re gauging aristo and USA motor block axels
Age old quest what is the best way to take apart and re gauge the drive axels on motor blocks? There almost impossible to pull apart any hints suggestions would greatly be appreciated.
Oops question sorry me bad
Easy to do on USAT. get a press from Harbor Freight… the axles press into a plastic gear casting, open the gearboxes and remove the axles. Impossible to do on Aristo, unless you have a lathe and or shim material.
See my web site under motive power, and USAT and Aristo.
Thanks Greg it worked
