Okay. You can exhale now. I know you’ve been holding your breath, just waiting for the mid-summer update. Well, wait no longer… Here it is…
The Mid-Summer Update!
(insert dramatic theme music here)
Progress continues at the feverish pace of a geriatric sloth on barbiturates. We’ve graduated from moving tons of dirt, to moving something even more exciting… tons of stone. Stone, as in BALLAST! Yep, that’s right. The time has come to lay some track. And maybe even lay some cable- you know… for track power. The two upper loops are completely ballasted and work has begun on the lower loop. There are no grade changes. When we finish with the coarse ballast, we will top it off with some finer stone dust.
All curves are 20 foot diameter or greater- mission accomplished. I used an Aristocraft Dual Rail bender and either bent some flex track or unbent some sectional track to make all curves. Tales of the deed can be found here:
http://largescalecentral.com/forums/topic/25588/aristocraft-dual-rail-bender
and here:
http://largescalecentral.com/forums/topic/25587/consecutive-rail-bending
Anyway, here are some update pics. 'Cause I know all y’all like pics!
Maple Curve is at the very front of the layout and now has two completed upper loops. The lower loop of track still needs ballasting.
This path is to the right of Maple Curve. The area on the right hand side where the small red line is, will be the continuation of the lower loop. The lower loop crosses the path after Maple Curve. I’ll need to make a proper grade crossing for the riding mower and people.
After the lower line is completed and ballasted, I will build a mountain here. The inner track will go through the black drain pipe tunnel. The track that is currently supported with cinder blocks will eventually skirt the back side of the mountain. I’ll probably reuse some of my old trestle and maybe a bridge or two, as well as some rock ledges to support that track.
On the other side of the mountain, I’ll install the water feature. If all goes well, the water will flow under this bridge. If not, then the bridge is gonna look real stupid here. We are currently in a state of drought, so digging really sucks. The ground is like concrete. But hey, I’ve got some experience using a shovel.
Eventually, I’d like to be able to run trains right out of the shop and on to the layout. So, I added this switching debacle in order to get trains from the shop to their respective tracks on the layout (I know- there’s an “S” curve, but I’m only using it to move trains on and off the layout). It ain’t pretty, but it will serve it’s purpose. I still have to extend the top most turnout towards the shop. Maybe next year. Oh… and the long single tunnel has been revamped into two smaller tunnels.
So there you have it. That’s my story and I’m sticking to it.
-Kevin.
