RCS has a revised operating program
Remote Control Systems (RCS) is pleased to announce a revamped operating system.
This latest version PRO-Av1 or PRO-Bv1 eliminates the need to use Ch # 5 for speed calibrating and programming. Instead, a small loco mounted pushbutton is supplied to select programming mode.
This eliminates the possibility of accidentally switching on Ch # 5 during operation which can cause problems with stored values.
It also frees up Ch # 5 for more accessories or allows the use of a 4 x Channel R/C instead of requiring 5 Channels.
So a 4 channel radio can be used now??
Dave
Yes Dave.
Even a 2 channel if you don’t want accessories like sound triggers.
