Tony,
I need an R/C install for my lil’ gas-mechanical switcher.
http://freightsheds.largescalecentral.com/users/richard_smith/MillSwitch-1-web.jpg
The space available is 2.5" long x 1.25" wide x 1.37" high. The measurements are pretty much the max available and ideally there should be at least a wee mite of slack.
http://freightsheds.largescalecentral.com/users/richard_smith/MillSwitch-4-web.jpg
http://freightsheds.largescalecentral.com/users/richard_smith/MillSwitch-5-web.jpg
http://freightsheds.largescalecentral.com/users/richard_smith/MillSwitch-6-web.jpg
http://freightsheds.largescalecentral.com/users/richard_smith/MillSwitch-7-web.jpg
http://freightsheds.largescalecentral.com/users/richard_smith/MillSwitch-8-web.jpg
The engine is brass and the motor is located underneath along with a toggle switch which controls forward, backwards and center off. There is no speed control. Power is supplied by a 9 volt battery.
http://freightsheds.largescalecentral.com/users/richard_smith/MillSwitch-2-web.jpg
http://freightsheds.largescalecentral.com/users/richard_smith/MillSwitch-3-web.jpg
What I need is a battery pack of at least 9volts (your 9.6 would probably work if it’ll fit) but preferably closer to 12 volts and connectors for easy removing for charging and a receiver for speed control all of which to fit the designated space. Additionally I’d need a simple charger and a transmitter with instructions written with an electronics dummy in mind.
I can do without sound or fancy features except the engine does have a working headlight that I’d like to keep. Can you fix me up?
email: [email protected] I’ll send you my phone number also after hearing from you.
Miss our old chat days Tony. You, me and ol’ Piute.
Regards, Richard Smith in Port Orford, Oregon, Center of the Universe.
