Having used my razor saw to remove the center wheels(molded plastic) from the deck of one of the HLW Macks I’ve repainted, it got me thinking about a trick that I learned years ago when I got into jewelry making.
When you purchase a new razor saw, (If) the blade is set in the holder to cut on the push stroke.
you can take a pliers and remove the blade from the holder and then turn it around
and put it back in the holder, you cut on a pull stroke.
You have much better control over your cut.
It makes it much easier if you’re making a vertical cut,
or are making a cut off where the end of the saw is
up next to something that you don’t want to cut…
I’m sure most of you older or should I say more experienced modelers know this trick,
but some of the newer folks may not be aware of it…
Dave…
:lol:
