A week ago , I used a fresh rattle can of Satin Black to coat a model .
Today , I needed to put an undercoat of black on a Tender prior to spraying the required finish .
I started off by grabbing last week’s rattle can , and as is my habit , I sprayed a test piece first .
Good job I did , it was “gritty” . That was the reason for testing first , I have found this with part used cans before .
It seems to happen with most rattle cans (except Games Workshop and Tamiya) . The reason for trying to use it as an undercoat is the cost of the the Games Workshop and Tamiya paints ; you get what you pay for I suppose .
It doesn’t happen every time , I can’t even pin down a particular make , but be advised , a quick test spray beats completely stripping back to etch primer and beyond .
Mike Brit
