So as I enter my planning and design stage for the new layout, I’m trying to think of ways/materials to use for construction of raised roadbed.
Option 1: Pressure treated wood on concrete pier blocks like Fred Mills and others use. Pressure treated wood for the base.
Option 2: Pressure treated wood for the posts on pier blocks, PVC trim boards for the “base”. Kind of like what Ken did.
In either option 1 or 2 pier blocks could be substituted with concrete holes with metal brackets.
Option 3: PVC posts in concrete, PVC trim boards for the base. Kind of like what our long gone friend Dirk was doing. But he was planning on burying everything.
Option 4: Steel tubing (say 1/2") in concrete. Make a T at the top with say 1/4" x 1" or 2" welded to the top of the post, then make a frame,with the same. Angle iron or similar welded about every 1-2’ to make a frame. This was my BIL suggestion. Once painted, it should last for a long time. BIL was thinking it $4.5-5 a linear foot. Haven’t costed out wood plus fasteners yet.
Thoughts? Ideas? For those that have used pressure treated wood, how are you planning one eventual replacement? Decks seem to last 15-20 years in this area. I’m 35, so 20 years puts a rebuild at 55, right around retirement age. Which could mean house relocation or not…
I’m in the rainy Seattle region. I’m guessing total layout run will eventually be under 500 linear feet.
