I’m connecting the flicker board on a Bachmann 2-Truck Shay to a RailBoss 4. Initially I thought that I could use a direct to battery connection but since the board apparently drives the lights based upon polarity and the firebox flicker changes intensity based upon voltage, that’s not going to work.
I’m guessing that it will be best is to use the RB4’s lighting connections:1, 3 & 4. Then connect the remaining flicker board power supply to the RB4’s M- and M+ connections along with the motors.
Does this sound correct to you all or does anyone have another suggestion?
Thanks, Mark
Cross posted to MLS.
