I am adding a couple of more pictures of the rail truck,
Here we have the axle out of the FA gear box, with modified c-16 tender wheels.
You can also see the sprocket and the chain drive.
This is a top view, you can see the motor mount, wires, top sprocket and chain.
I made it so the rear axle could pivot to allow the truck to track better over uneven track.
You can also see the red tail lights I added using 3mm LED’s
Here is a view of the front, I drilled out the solid plastic lights and installed yellow 3mm LED’s.
I then potted the LED’s in Epoxy, this was not a good Idea. I think maybe if I had used white LED’s
it would have turned out better, but now it is very hard to even see the lights. I will try again.
You can also see the power pickup on the front wheels.
And here is the driver I stuffed in the cab. I still have to finish the box truck roof.
a little more detail, and I think she will be finished.
If you have any ideas on the head lights please let me know. They look good, they just don’t
function as I would like.
