On narrow gauge railroads like the Rio Grande Southern, both rail size and rail length increased over time. Rail size grew as locomotives and cars got heavier. Rail length was generally determined by the length of available flat cars for transporting the rail. Before about 1900, most of the early, lighter rails were 35 lb/yd. During the 1900s - 1920s, much of the line was upgraded to heavier 65 lb/yd rail. Modern 80 lb/yd rail did not appear until the 1930s and, as far as I can tell, was never used on the RGS, although it may have been used on other narrow gauge lines. On some standard gauge line, the maximum rail size was up to 155lb/yd.
Rail sizes in 1:20.3 scale
Narrow gauge modelers like myself are pretty much limited to using Code 250 and below for representing prototypical track sizes. Here are the approximate equivalents:
Code 148 = 35lb/yd
Code 215 = 65lb/yd
Code 250 = 80lb/yd
Code 332 = not prototypical
Rail sizes vs. Rail lengths
Rails in the 25 to 60 lb/yard range were usually 30’ long; 60 to 90 lb/yard were usually 33’ long; and 90 to 115 lbs/yard were usually 39’ long.
Used Rail Lengths
When lighter rail sections were replaced, the old rail was often re-used on branch lines and sidings or as guard rails on bridges. Often, 6” would be cut from the rail ends to remove damage. Therefore, re-used 35lb/yd rails are generally 29 feet long and re-used 65lb/yd rails are generally 32 feet long.
Track is a Model, Too
Since I use Code 215 rail for running rail, I scribe the rail head every 19 ½” to represent 33-foot long sections of 65 lb/yd rail. I use Code 148 for guard rails and cut them to 17 1/8” to represent 29-foot long sections of used 35 lb/yd rail. These little extra touches do not require much additional work, but they add another degree of realism to the layout. As modelers, we all deal with a lot of compromises. Realistic looking track shouldn’t be one of them.
