Dan Padova said:
Let’s all play nicely. John, your input into my query is well appreciated. I know Greg’s responses can sound a bit condescending at times. However I believe he is well meaning. It’s difficult to understand nuances in the written form. I find it hard to believe that the various rail clamp manufacturers don’t by readily available extrusions, or at the least extrusions that already have the shape in them that is required, but that may need some trimming to get the extrusion required out of them. Of the three rail clamp manufacturers out there, Hillman, Slpitjaw and Uncle Herms, I doubt they all have extrusion machinery. However, I may be wrong in my presumption.
The clamps are machined from solid brass, stainless or alu. From my previous life I’m familiar with a machine that was used to produce the connectors for the “Neutral” in distribution boxes. Feed in the bar, drill and tap the holes, cut off to length. All fully auto and in whatever length (number of connections) required. But … I doubt that the clamp mfgs would go that expensive route.
They buy the bar and then machine the dovetail, drill and tap the holes in a multi-station op and cut-off. Next cut the part length wise to get the two halves.
BTW I was planning on producing some insulating clamps, looked at the price of the dove tail cutter and said … not too bloody likely.
Now tha SplitJaw has their website up and running I’ll order the stuff. Getting info from those guys, when the site was out, was not a pleasant experience. GRRRR
