I have been sorta’ following a few of your threads. In this one your talking of using .215 rail and in another I believe your thinking of using small cars and engines (stock?) to run on it. Sometimes those over scale wheel sets have a little trouble running on that low a profile rail, especially through switches. Just something you may not have considered.
On rail bending and hand spiking.
As a little background for you; Through the years I have built 2 single rail benders, one from scratch and one from parts, as well as using a dual bender on many hundreds of feet of track in both code .332 and .250 in brass and aluminum. Also been down the road many miles on hand sawing Redwood ties and spiking rails of brass as well as aluminum, including building switches in both metals as well as Nickle Silver.
Some of the things I learned that worked best for me.
Dual rail benders are just that, to be used on duel rails held in gauge by tie strips. They work fantastic to curve or even straighten pre-assembled trackage. I don’t have one in front of me right now but I believe it would be almost impossible to run a single rail through it as there is no way to crank it through. The ones I have seen sit on the track and are pushed along by hand producing the curvature , I have found it best not to try to produce the final curve in one pass but to use multiple passes to bring it to the desired curve. Trying to hold a single .215 aluminum rail and push the device along, problematic at best.
Hand laying track I use a single rail bender to produce the curve required. The curvature is not critical especially for 215-250 aluminum because of the tremendous amount of flex in the material. Have your centerline on your ties and some good rail gauges, get 3 point gauges for your curves, and spike away. Always wide never tight, remember were talking thousandths. I know the experts throw lots of impressive sounding numbers around when it comes to back to back on wheels and gauge between rails but the fact is the very best wheel sets in the hobby are only semi-scale with over wide tire face and nothing from a factory is going to have consistant numbers even on the same engine or car.
Using a single bender especially on soft material like aluminum it is CRITICAL to keep the rail on a flat plane while bending. By this I mean keep the rail foot or head flat to the table and 90 degrees to the bender rolls. Letting it twist out of plane will produce, well a twist in the rail, not real noticeable to the eye but once it is spiked down flat it will fight the spikes and try to rise to the twist creating an out of gauge problem that can be difficult to figure out. Does any of that make sense?(http://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-smile.gif)
Spikes. If your spiking outdoors do not use stainless steel spikes unless you are clenching them under so they can not climb out of the wood. Indoors they should work fine. Steel spikes rust and lock into the wood better, not perfect by any means but far better than stainless.
Just a few things that work best for me may or may not be of any help to you.
Rick
