Radical fix for worn out Accucraft trucks
Last spring at the ECLSTS I picked up a few “lightly used” Accucraft Fn3 cars art a very good price. I’ve had quite a bit of trouble with them not wanting to track through switches and track work that all my other Accucraft cars get through fine. I finally bad-ordered one of them and got to it yesterday.
I removed the trucks for inspection. I had previously checked and adjusted the back-to back gauge and they were still fine. As far as I can tell the car does not have the problematic wheel profile of early Accucraft cars and it does have the L bracket in place to keep the side-frames from canting.
What I did find was extreme side-to-side play of the axles which allowed the side frames to easily go out of square with the bolster. On closer inspection I found that the journal bearings were very worn allowing lots of play between the axle end and the bushing.
The “correct” fix would have been to replace the bushings, but since I don’t have any in stock, nor do I know if they are even available, I decided on an extreme fix: Modify the side frames to accept USA wheel sets. Before I started I knew the wheel size difference would lower the car a bit and might affect coupler match. I did a comparison of axle centers before I started and decided that the difference was acceptable to me, but YMMV.
The USA wheel axles are too long for the Accucrafrt trucks and the axle end is a smaller diameter than the Accucraft axel. The USA wheel does have a larger diameter shoulder outside the wheel which is a bit larger than the Accucraft axle. To make them fit; both the USA wheel sets and the Accucraft bushings need to be modified. The axles are cut short; I took off about 3/16" by eye with a Dremel cut-off wheel then smoothed the cut. The Journal bushing was drilled out to be just larger than the shoulder of the USA wheel…
The axle ends and bushings are oiled and re-assembled…
The result is little to no side-to-side play…
This fix isn’t for everyone. For starters the over sized USA flange may bother you and/or the change in wheel diameter and resulting overall car height / coupler height could also be a problem for you. Since I run prototypical operations with lots of track switches, reliable tracking is much more important to me than esthetics. As Bart and Bob call it; “Operations Quality” This is the second car I’ve made this change to and may not be the last!
BTW - When drilling out the bushings I found one of them was copper, not brass. I wonder if early Accucraft trucks used copper bushings, or if somewhere along the line a replacement was fashioned by the previous owner?
John , that looks to be an elegant solution , and as long as you enjoy doing it you’ve saved a fair outlay .
I take it the trucks were under-lubricated and that caused the problem ?
In any case , it makes a good reminder of the need for rolling stock maintenance .
Mike Brit
Mike - Since I bought the car second hand I don’t know if it was under-lubrication or just a lot of use, or a combination. About to run some track trials now. Hopefully it’s problem solved!
Nice.
You call it “Operations quality”, here we call them “running models”, it works out the same. If they work good, and can pass using the 10 foot rule, its good enough.
Track trials were a success, but the car leading this one started to have the same issue. I found the same sloppy side-to-side play and tendency to go out of square, but this time the bushings were fine; the problem was loose screws where the side frame attaches to the bolster. Tightened them up and ran some trials - problem solved.
