those, who build an indoors layout often can not evade some R1 (2ft. radius) curves.
(even in my 46 by 16 ft. room the only way, to not use R1 in some places, would have
been a boring one-loop-roundy-round)
so we have to live with the problems.
as for instance the ugly overhang of longer locos and stock
(the (parcial) solution: try to hide most curves behind buildings or in tunnels.)
the idea of this thread is, to collect solutions for the known R1 problems.
on former layouts i have used my R1 curves only with short stock. (1ft. and shorter).
now, as my new layout is so far advanced, that i have a (shortened) complete loop.
so it was time for driving tests.
first locos only - put in some jumpers.
then short roling stock (4 wheels) - prolongated some changes of grade, to eliminate
uncoupling.
then 16" (40cm)(8 wheels) long cars. - oh, oh…
there were some points of the track, where the cars derailed.
remarkable was, that always the first aixle of the front-truck derailed towards the
outside of a curve. and, that by changing the direction of the trains there were other
points of derailment.
and, notably, the problem got greater, the more weight i gave the cars.
as it is well known, that body-mounted couplers, or even truck-mounted
knucklecouplers don’t like sharp curves, so the cars are fitted with bottleopeners. (true to
Fr. Fred’s gospel)
well, closer inspection showed, that the derailments all occurred on the last four or five
inches of an R1 curve, where a straight followed.
setting up a short test track, i could visualize the problem.
position of the loops in the R1 curve:
position of the loops, when the first car is already on the straight, the second still in the
curve:
so i supposed, that the coupler of the first car did push the coupler and truck of the second car out of the curve.
my solution:
i toyed around with guardrails.
(for the moment just “glued” down with silicon-sealer)
it works.
do you have some tricks/solutions for R1 problems as well?
