Just finished up this little project, installing Deltang R/C and Seirra sound in a ‘new’ Bachmann Climax. This is equipt with the Super Socket, which caused all sorts of issues with a non PNP receiver, a real waste of space imo. I also upgraded the speaker to a Visaton 2.3" FR 58:
To get the new speaker to fit under the Bachmann PCB, the mounting flange had to be ground off and the speaker pushed back towards the cab, I was able to take 1.5mm of the height of the mounting posts.
Wiring was directly soldered to the PCB, avoiding using a blanking plug.
The new reciever mounted on end, the PWM to linear convertor next to the speaker and the Sierra on top (powered by a 5v convertor).
Everything fits, just!
The battery was fun to come up with… I used 4x li-ion 18650 cells and a 4s Protection PCB (under tape). A small slide switch is just visable and accessable though cab doorway.
Charge socket, hidden under water fill cap:
All fits together nicely and full well.
