I am going to venture down the path of DCC on my indoor. I have a pretty okay understanding of the basics in wiring. I understand that the power and signal come from a main set of bus wires under the track that feeders are then attached to the track much the same as conventional DC.
My quick question is this. In order to get into the closet I will be making a section of lift out track. The bus wires will be run under another section of track to feed the two “halves” of my layout so no concern there. I think I know the answer to this but would I wire the lift out section like it is a stand alone block. Can I just attach a set of feeders from the permanent section of track adjacent to the lift out section and utilize a plug in that feeder line to disconnect the removable section?
