Pete’s first link looks like the exact same device and the instructions seem to be the same as on the eBay page…
Learning method :
press the learning button on the receiver board .when you hear the sound :“BI”
it means enter into the learning state , and then press the relative button of the remote control .when you hear the 3 sound “BIBIBI” ,it means learn successfully ,
A: Signal non-lock(jog): press the NO.1 button of the remote control to learn
B: Signal self-lock:(self-lock): press the No.3 button to learn ,each channel is independent of the others ,
C: Signal inter-lock: press the NO.2 button to learn
D: 1CH-4CH is jog, 5CH-8CH is self-lock press the NO.4button to learn
E: 1CH-4CH is jog, 5CH-8CH is inter-lock press the NO.5button to learn
F: 1CH-4CH is inter-lock, 5CH-8CH is self-lock press the NO.6 button to learn
clearing method:
press the learning button for about 10 seconds ,and when you hear “BI” again. it means clear successfully ,
Can’t say I can make any sense of that either - for starters; what sound is BI? I suppose that’s whatever sound it makes and if it repeats 3 times that means you did good. There is only one button on the board that I can see, so that must be the Learn button. My problem is I don’t know teh difference betweem self-lock and inter-lock. I’m pretty sure lock means latch, but that’s where I get lost.
