I’m about to pour a concrete pad for two new switches directly next to an existing pad [See This Thread for details]
Should I tie the two pads together - or let them float in the ground independently?
I could drill the end of the existing pad and set some rebar in place to tie it to the new pad - OR - I could install an expansion joint between them -OR- I could just pour the new one tight to the old one.
I’m concerned that if I don’t tie them together I may end un with height difference at the joint after a winter or two. On the other hand, if they are tied together movement of one may cause the other to crack.
What would you do ?
I have to go find Cozad’s article on Concrete Roadbed (if I’m still allowed to read it) and see what he does.
