Quote:
You cannot assign a number to a loco that is related to it's road number... clear enough?
The cab number has nothing to do with the locomotive number. It's not designed to. The Cab number refers only to the order in which whatever loco, consist, or accessory you wish to control appears as you scroll through the active cabs. That's [i]all[/i]. The Revolution does not define locos based on cab numbers, it defines them on the specific descriptor you type in for each "bind address." You're correct - you can't assign cab numbers based on road numbers (well, you [i]could,[/i] up to loco #49), but the system is not designed to have that relationship. The cab number is strictly an indicator of a place in line, and you need only activate as many places in line as you have locomotives/consists/accessories to control on any given operating session.
Quote:
The emergency stop works on the "bind address", "loco id", "loco number", whatever the frigg Aristo calls it today. It's THOSE numbers the emergency stop works on and those numbers should be allocated from the beginning, since that is how emergency stop works, blindly issuing stop commands to loco id 00, then 01, etc.
The emergency stop ("all stop") feature works via the [i]cab number,[/i] not bind address (Loco ID, etc.) It starts at [i]cab[/i] 0, then cab 1, cab 2, etc. until the end of the active cabs, not caring what is actually controlled by that particular cab. You see that when you hit the "all stop" button, and the screen displays the cabs in numerical order as it sends the stop command to each one. If the locos on cabs 0 - 4 have respective bind addresses of 49, 2, 23, 7, and 36, that's the order in which they'll stop.
We’re in absolute agreement, but getting hung up in the terminology. To maximize the efficiency of the “all stop” command, you want to allocate your active locos to the first cabs. How locos are linked to their specific bind addresses (Loco IDs) has nothing to do with it. You could start at 49 and work backwards on the bind addresses, or choose them based on the date when you program the receiver, or however you want to. Its strictly how they’re then assigned to the active cabs–where they are in line–that determines the order in which they’ll stop. Pick the locos you’re going to be running, and assign their IDs to cabs 0 through however many you need.
