Not really a review, but there’s some new features in the Titan that can use some more explanation, and new things that you want to set first.
In particular, setting the auto chuff rate is a two step process, entering the scale size of the drivers, and then the “gear ratio”.
Seems like more complication, but once set, then the scale miles per hour are set, the odometer function works (can tell you the scale number of miles run over lifetime) and of course the chuffs are right.
Also, once set you can change the number of chuffs per revolution with a single command just to do this.
Also, the Titan now will drive the fan motor in a smoke unit and pulse it in exact sync with the chuff.
The smoke unit heater can also be controlled, and it needs to be controlled since you can melt things down from too much heat, most elements work on 6 or 7 volts.
So, not a commercial here, although I’ve been helping QSI do beta testing.
Links to my site:
