I decided that I will need sound for several Aristo Craft and USAT diesels that I already have.
I purchased a QSI NCE pro-cab throttle, 1 x Quantum Aristo sound decoder, 2 x QSI Magnum decoders and 3 x QSI GWire receivers.
Being new to DCC control, the first locomotive sound/control install I attempted was the Aristo Craft Dash 9.
Installed the PnP sound decoder and receiver in the loco, no problems, easy install, now to program the NCE throttle.
The only programming I made was to program in a long address for the loco road number.
The power source I am using is from an Aristo Craft older train engineer, suppling about 5amps, with 20.7 volts at the rail.
I powered up the track, loco lights and sound OK at idle, in forward direction the loco did not respond until I applied about 10-12 volts, then the loco took off at speed. I understand that I will have to change the CV for ‘slow start” response.
The problem I have is that when I change direction to reverse on the throttle, the loco just sits at idle and won’t back up, no matter how much voltage is applied, even though the NCE indicates REV has been selected.
Changed power supply to another transformer, but still the same problem, foward OK, no reverse.
Went back to the original Aristo power supply, set the loco to forward on the NCE, the loco moved about 3 feet then stoped, no sound or lights and the circuit breaker tripped on the transformer, now each time I turn on the transformer, the CB trips.
Removed the decoder and tested the loco with the bridging plug replaced and the loco operates fine. How when I install the decoder I get a short circuit, so looks like the decoder is damaged.
I replaced the original decoder with one from the Magnum non PnP board, this one works, but still with the same problem of not being able the select reverse direction.
I hope I can get some help with the reversing problem and it looks like I will have to return the ‘maybe’ damaged decoder to QSI for them to check out.
I think it will be best that I hold off the other installs untill I find out what I am doing wrong.
Wayne
