Doug Arnold said:
The buildings are looking good. What did you glue them with? The one plastic building on my layout is a Piko kit and I glued it with Piko's glue. After a year it fell apart! I have several kits waiting for construction. I have a new bottle of Testor's Plastic Cement but haven't tried it.
The Testor's liguid plastic cement used to be good years ago. Until they removed most of the MEK.
The solvent MEK works real well. But I would only work with it outdoors.
I used Homax Professional Welder on the Yardmaster’s Office. Time will tell if it holds up.
I used CA on the Tower. I built it before I ever put any track down. So it is about 2 years old.
I have another Tower that fell apart. Amazing Goop wasn’t so amazing. I repaired it using the Homax Welder.
If these fall apart, I will be building outdoors with MEK.
