So we have lots of discussion on here about what adhesives will “glue” one material to another. I now see where Rick has used Flex seal as an adhesive and I am very curious about this as I still think a hybrid foam core skinned in styrene sheets would be the way to go for building construction. But not sure what adhesive would make a strong bond between the two. MEK eats foam as does CA.
Then as I was replying to another thread It got me thinking about my current challenge build and I want a PVC base and then the bulk of the structure will be styrene. Anyone know if there is a chemical that will weld the two together as opposed to just gluing them. CA will bond the two, I know that. But MEK doesn’t melt PVC as far as I know. Does PVC cement melt styrene? Or does someone know of something else?
