I was reading an article by the late Peter Jones in the June 2008 issue of Garden Railways in which he recommends the use of PVA glue as a preservative for wood used in outdoor models. He assumes that the reader knows what PVA glue is and doesn’t describe said product.
A search of the internet is less than revealing, because the entering “PVA GLUE” into my favorite search engine yields this:
PVA (Polyvinyl acetates) are probably the most common adhesive on the market. They come in a variety of formulas, all ever so slightly different, and specific to what they are designed to glue. Here are some tips for using Polyvinyl acetates.
- All PVAs are designed to work on porous materials only
 - PVAs are water based, and clean up with warm soapy water.
 - PVA is only toxic to ingest, it does not emit any harmful fumes, and is not hazardous to touch
 - PVA sets best in good air circulation, at room temperature.
 - PVAs need pressure to adhere, see our info on clamping.
 - Most PVAs are not water proof. The yellow PVAs have a higher moisture resistance than the white ones, but neither are completely water proof.
 - Never allow your PVAs to freeze. This breaks down the polymers and your glue will be rendered useless!
 - Yellow PVAs have a shorter shelf life than white PVAs.
 - Be wary of over priced PVAs that claim to be for a specific use. There is very little difference from one PVA to the other, and nothing that should increase the cost.
 - Although PVA is not a gap filler, in some cases you can add sawdust to it to increase its gap filling ability.
I don’t think this is what Peter was refering to.
Any ideas?
