Tom,
There is a new style of “pressure treated” lumber on the market, but it is not in wide distribution yet. Rather than using toxic chemicals, the lumber is cooked under pressure with silicates and they end up replacing the water. In effect, a composite is made of the wood and glass! It is called Timbersil:
http://www.timbersilwood.com/
There is a place on the north shore of Boston that carries the stuff and I’ve been meaning to get up there to get a few pieces for testing purposes.
It is supposedly waterproof in terms of rot for the uncut wood as there is a hard surface layer of glass that protects the inner core that has a lower density of the glass infused into it. In fact, an uncut factory post end is warranted against rot if buried in the ground; cut ends to be buried need to be treated with AnchorSeal - an epoxy like product. There are guidelines for installation on their website in a six page pdf.
Don’t know what it costs, but I’m sure it ain’t cheap; the real cost savings would be in never having to replace it or to realign your right-of-way, etc.
Given our requirements, one thing I was wondering about is how tight of a radius could you bend it to - especially given that it has this dense glass coating.
If you do find some, please report back on how it works.
Brian
Taxachusetts
