I am aware that it is not April 1st, but had a thought in relation to using full power to the rails and then altering the power sensed at the motor terminals using an ‘onboard’ Aristo 27 meg trackside receiver monted in a tender or rolling stock. This would entail routing all power pickups to the tender or rolling stock and then an umbilical cord to the locomotive. I feel that the advantage would be full track power for smoke units and lighting intensity plus the advantage of having full power to the rails, which I believe would aid in power dropoff/pickup.
This would in effect be a R/C DCC control with the receiver acting as the decoder. What are the possibilities, pros and cons of such a system? A ten-amp decoder would be as expensive as the Aristo 27 meg receiver. With the later transmitters going into sleep mode, this may be a problem and access to a complete power cutoff switch at the power supply would be a necessity. Is this a pipe dream or a reality???
Some may say why not simply provide battery power and simplify the scenario. however, the prospect of full voltage power to the rails with onboard control stimulates my thought process. I am wholeheartedly anti-DCC, so this form of control is not an option. This would limit one taking a loco to another railroad as the installation would need to be specific for the power control intended, unless a conversion switch was incorporated.
