I never know which forum category to place questions like this, but I hope this will work.
I took some pictures on a local siding near Santa Fe Drive of steel-sided boxcar couplings and some tanker couplings.
It looks to me as if the boxcar couplers are in draft boxes which stick out a lot farther from the body of the car itself than I imagined they should. When I’m installing body-mounted kadee couplers, I was about to install them with the lip of the draft box right against the wall of the body…but here in this picture you can see that the draft box is way out from there. That would be good in a model in one sense because it gives you an ability to run a tighter curve and also reduces the chance of the wheels hitting the inside corners of the draft box on turns.
My question is this: is this picture a normal situation? Do I need to go out and make more observations of this?
I also include the tanker-coupling picture for comparison because the tanker couplers seem to be much closer to the frame of the body of the tanker.
Thanks.
p.s. I’m not what they call a rivet counter, but I like to be reasonably accurate where I can, and this seems to me to be worth nailing down since I have a lot of rolling stock I want to look right.
The result is normally because of improper blocking… Lots of rules on what cars can go where in the train.
