I am converting my Bachmann Indy Mogul to battery power using a 14.4 LiPo battery, Airwire G2 and a Phoenix Model 97 sound card. I have this all setup on my bench and it works great except for the Bell and Whistle.
According to the diagram I got from Phoenix (which was for the G3 which was what I was originally going to use) they tell me to change Function1 with CV 35 = 4 and Function 4 with CV 38 = 3. So I did this and when I press on the function keys nothing happens, I was messing around with all kinds of key combinations and discovered if I hit the Function 1 Key and the pressed down on throttle knob the horn would work, same with Function 4, if I pressed the Function 4 key and then pressed down on the throttle knob the bell would ring, The problem with this is when you press down on the throttle button it also changes the direction of the motor.
Anybody have any thought what I am doing wrong?
Also, I ended up having neither of the functions work anymore and when I went back to re program the functions the CV values were blank. Should the T5000 show the current value for a CV or does it always show empty when in program mode?
I was using OPS mode if that makes any difference.
Thanks in advance
