I thought I’d “launch” the forum, ha ha.
This is a typical problem, the back to back gauge is very narrow on “new” Aristo locos. I will confine myself to the Aristo locomotives using the “new” “prime mover” gearbox. This is the “modular” system where the gearbox is totally enclosed, with hex recesses on each end for the drive and 2 metal half axles affixed to the center plastic worm gear.
I’ve never seen one out of the box with the back to back too wide. The wheels have a tapered opening for the axle shafts, and the ends of the axle have a matching taper.
The problem here is how to space the wheels out further.
- Shim the wheel.
One way is to try a thin shim on the end of the axle between the axle and the wheel. There is a common problem with wheels slipping on the axles already, and Aristo often puts Loctite red here, so I think this is a poor solution. Also unless you can make a “perfect” shim, you will probably get more wheel “wobble” / runout.
If you want to try this, try making a pie-shaped shim, then cutting the tip off. This should give you a good start at covering the end of the axle well.
I would recommend “lapping” the wheel to the axles first, to improve the fit. I use medium valve lapping compound.
- Remove material from the back side of the wheel.
This is actually pretty simple and easy. You remove the wheel and put it in a lathe (oops you need a lathe buddy), and remove material from the backside of the wheel. The upside is the ease to do this. The downside, besides needing a lathe, is that Aristo wheels are steel, and you will have turned off the plating. It’s not a big deal since it’s on the backside, and the plating wears off the tread anyway.
- Shim the half axle out.
This is the most elegant way, but the most time consuming, and you have to buy shims. Outback turnouts in Australia makes shims (I believe he still has them) or you can make your own shims. You take the gearboxes out, unscrew one half axle from the worm gear, put a shim in place and put it back together. The downside is that you have to remove the gearboxes and pull them apart. The upside is that everything will still run true and you do not need a lathe.
Well, that’s my problem solving info I have discovered when I started figuring out why my locos had so much trouble at switches and picking points, etc.
Regards, Greg
