Clair Dise said:
Hi Nicholas Thanks for the reply. I liked the video's. The long trains were great. I usually don't cover that much area so the trains are shorter.A few questions, If you don’t mind.
What is the green covering over the tables?
What size curves is the club using?
How are the posts made that hold the string(crowd control)Thanks all for the responses, it has been helpful.
Clair
Clair,
The green stuff is indoor outdoor grass carpet from Lowes
Curves are mostly 20’s and some 18ft Dia.
The exstandtions are made from 2 pieces of 1ft 2 by 4’s screwed
together and then a hole was drilled to allow rope to go thru,
Base for the 2 by 4’s were made from scrap pieces of
plywood cut to 1ft squares. Everything is screwed together
with sheet rock screws.
Nick
