I have a bunch of LGB track outside whose slip on joiners wore out as they always do. I could go with the expensive rail clamps or tedious soldering of jumper wires, but…
What if I just drilled holes into the track joiners? You know, like how Aristocraft track works.
I drilled through about 8 joiners before the drill bit broke, but otherwise, it seems promising. What are your thoughts regarding this? I don’t want to drill through all my track if it’s a bad idea.
Drill bit was 1/16 inch, screws were I think marklin screws for holding HO track to the table (I had to use what was available :P)
