I haven’t turned up any good leads on a local portable track for rent or purchase so I’m doing some R&D to figure out what building from scratch would cost. The questions I have about the design are related to how close is acceptable for track to be from the edge. I’m trying to lay things out so that I use as much of a sheet of plywood as possible and thus have the largest diameter curves as possible. The picture below show what I have come up with as a maximum size. Six of these segments would for one end and use 1.5 sheets of plywood. Seeing the track centerlines on the drawing dose this put the track too close to the edge on the out side and corners on the inside ? What are most operators comfort zones ? There would be no vertical wall, just a flat surface with the track.
