With the days being shorter there is a lot less time for running trains. There are times I want to run some trains either to test something out or just sit back and watch some trains run. For the last few year have been setting up track on the garage floor. After a while it gets old having the track on the ground, especially if Im trying to test something or work on something like live steam. I decided I needed a portable steam layout. I saw an article in steam in the garden and two people building one over on MLS. It got me thinking. I have 6ft circle of track and a few 4ft straights. I started out with the 6ft. I cut the boards on the outside but giving room to add 8ft curves eventually. I have it in 6 sections and the center cut out to save space and cut weight. I also left some room on the inside for some building. I also plan on using it outdoors during club meetings to run some live steamers that cant handle my grades. I started adding some bracing to the bottom then I will add some legs and then come up with a way to connect the pieces. (I have a few ideas) The top will be painted and some dirt to give it a more natural look. So far this is what it looks like.
