For those who wondered why the photos disappeared here; they were deleted from my freight shed storage when LSC suffered an attack last Saturday. I’ve reconstituted the photos (hopefully the right ones in the right places). I have endeavored over the years to keep the photos current on all my posts to avoid the dreaded little red “x’s”. Sorry for the inconvenience. [b]I always admired the Santa Fe’s early blind end cabooses and wanted one for the POC. A Bachmann chassis, floor, underframe & trucks was used upon which the car was built.
The walls are 1/8" PVC sheet that I scribed myself. The interior blocks and ends are 1/2" PVC.
Roof sections and roof walks were cut from the original Bachmann boxcar roof.
The cupola is a one piece acrylic box that just slides into the top of the caboose. It houses the battery, a SPST switch and the bulb wires. Perfect fit, brilliant Richard! Now, how the blazes am I supposed to get the stuff inside of it. Too thick to cut easily now. Oh well that’s what a drill press is for. hehehe! Doesn’t have to be neat since it won’t show.
The cupola assembly set in the car.
With its roof on. The roof is from an old Aristo caboose although it would be simple to scratch build.
Didn’t come out too bad. The cupola was sheathed with strip styrene from Evergreen.
The cupola off. You can see the battery, etc., inside.
I kind’a like the proportions.
Ready for service. Paint color is Bondo’s grey primer.
All hardware is by Ozark and couplers are Kadee 831’s truck mounted. They zig zag upwards to match the height of body mounted couplers so both types can be used together. The chimney is two pieces of aluminum tubing.
So now you’ve seen how to scratch-bash a blind end caboose and how not to build a cupola with access inside.
There were many examples of such cabooses built from older, existing box cars, etc. This one follows no prototype except the POC R.R. but was inspired by those on the Santa Fe; just one example of blind end, side door cabooses. It could be built with end platforms and doors too and still retain the side doors. The Santa Fe and other roads had many examples of that kind too.[/b]
