RCS is pleased to announce two PnP kits for most four axle USAT locos are now available.
There are two versions of the kit for battery power only. The pcb’s in the locos are used as is. The kits are installed by simply swapping over plugs and sockets. They can be used by virtually any brand of Radio Control.
BIK-USAv2. This is the basic version and comprises our well known # BIK-U3 kit plus two female cables for the ESC to loco connection.
When installed this kit enables the USAT loco to operate just like it would on track power. The lights and smoke etc are OFF when stationary and come on appropriately when the loco is accelerated in either direction.
Installation involves simply unplugging the JST connectors USAT uses and replaces the track pick up connections with the same JST connectors which are supplied by RCS.
BIK-USAv3. This is the next level and includes the # BIK-U3 kit plus a # RELAY and 3 JST female cables.
Power for the motors is sent direct to the motors via plugs and sockets. This permits the # RELAY to provide constant brightness lighting that follows direction. It is also connected via the supplied cable to the existing USAT pcb.
Shortly, RCS will have another kit available designed for PnP installation using track power with battery back up.
