Okay so I was asked about plumbing and I think this is a valuable tool to have in our arsenal. I created a PDF write up with pictures. You can download it HERE
Here are the pictures
The PDF goes into detail and has pictures of the process. But its really pretty simple. First Let me thank Rick Marty for the wire idea and expanding on it. I had done it before but I took what he taught me and ran with it.
My goal is to make complete runs of plumbing as one unit. By soldering the wire for Tees and what not and sliding the pieces of insulation on as you build you can make a very rigid plumbing run that reliess on the solder joint and not glue for the joint strength. Use super glue gel. It not only glues the insulation in place but is a gap filler as well.
