What do you call this plug and where is the best place to get them?
Thanks for any help
I don’t know if it’s the same thing as these connectors. But I have these to use as connectors.
WayinTop Connector Crimping Tool Kit Crimper Plier 2.54mm Header Male Female Crimp Pins Terminals Housing 1 2 3 4 5 6 8 10 Pin and 40pin 1.27mm Ribbon Cable FC/IDC Jumper Wire 1M (Crimping Set) WayinTop Connector Crimping Tool Kit Crimper Plier 2.54mm Header Male Female Crimp Pins Terminals Housing 1 2 3 4 5 6 8 10 Pin and 40pin 1.27mm Ribbon Cable FC/IDC Jumper Wire 1M (Crimping Set) - Amazon.com
Rick, you can buy 6 pin JST harnesses, both male and female as a set.
Problem is you might have to get 10 of them per order.
You could also use 2 3 pin JST’s.
Here’s is one
Thanks for the information guys.
I want to make sure they mate with my existing plugs from my trail car.
I’ll give these a try John.
I don’t know if they will mate, Rick. I assumed you would replace both.
John, I don’t really want to rewire 6 rail cars just so I can add a seventh
I’ll order a couple of sets and see what happens.
If you google JST SM you’ll find the technical specs, which will include pin spacings.
