This the start generic figure that all your renderings will evolve from, male, female young old etc.
Now you tweak using all the designing tabs in the program. I just did a grumpy middle aged dude.
Add some clothes from the limited library MakeHuman has. (If you can’t use the Assets, because your OS is too new for MakeHuman.)
And export it as an STL file so you can load it to your printer. You have to adjust the size, (Scale you want) before you hit the print start button.
STL file rendered to 1600x1600 resolution.
If some one wants this STL file, message me with your email address and I’ll send it to you to play around with on your printer.
