The following is from TRAINFAN1, a response I found after using Google and the heading “Plastic Compatible Oil.” Clearly, this author is adamant there is no damage to our hobby from using a “non-plastic compatible” oil. It is worth a read.
David Nebenzahl wrote:
"Folks, I’m here to bust another of those persistent myths that linger around the world of model railroading. Today’s target: “plastic-compatible oil”. I’ve heard this said enough around here recently that this myth deserves to be put to rest, again.
"This seems to be another of those claims made by the manufacturers of certain products, which strikes enough fear in the heart of the consumer for them to choose their product over someone else’s.
"I challenge anyone to find an oil that will actually damage the plastics used in model railroad drives, which are mostly so-called acetal or “engineering” plastic (strictly speaking, polyoxymethylene). This material is by nature resistant to all oils, greases and most solvents except the very strongest (like acetone, MEK, etc.) This stands to reason, since this plastic is formulated for use as gears and cams, which typically need lubrication.
"I’ve used ordinary oil and grease on plastic gears for years with no ill effects. No oil or grease is going to dissolve or break down your Athearn or Kato (or even Overland) gearboxes. (For grease, I keep a can of white lithium wheel bearing grease handy: works like a charm.) "
---------------- end of quote --------
The big question: So is there any emperical data from our readers to support the author’s claim other than his stated experience? Has anyone literally soaked gear parts in “dino oil” or "3-in-One or ?? and affirmed damage done compared to “mineral” or synthetic? Over what time period was the comparison made? Is David accurate that we are simply repeating what seems logical but a myth?
After my “conversion” to synthetic Mobile 1 as the main lubricant at the Living Desert garden RR display in Palm Desert, Calif., I now use only a plastic compatible oil. Clearly, I am still interested in the on-going debate as to the damage or non-damage that is acclaimed to be prevented. Over the year of use, I have lubed over 50 locos and 100 rolling stock wheel journals. No problem reported from the use of this synthetic. Of course, to favor David’s claim, this does not prove there would have been damage if a “non-compatible” oil was used.
Lastly: If the data is conclusive certain oils are damaging to plastic gears, and author David Nebenzahl is in error, what is a “non-compatible” oil? Is it “dino oil” vs. certain types of mineral based oil? Does synthetic resolve the entire situation by being BOTH compatible and the cheapest choice?
What evidence do you have that is conclusive and not myth?
Wendell
