Bob, I’m trying to post some pixs of a critter I bashed from my freight shed, but the preview keeps turning them into links. ???
whudda I’m doin’ wrong?
I tried this:
http://www.lscdata.com/users/jebouck/ccrrcritter%20(1).jpg
and it didn’t work either.
j
John!!!
Don’ say yo’ in trubble , yo’ da man who taut me ! Wot I gonna do now , huh ?
Mike
Mikey,
Working on it!
I think it might be the name I put on the pixs. I used a parentheses. ( )
I’m re-loading them with a different name.
j
Bob, I found the problem! I named the pictures with a ( ) like:
critter(1) critter(2) etc.
lesson learned!
problem fixed!
j
John Bouck said:
Mikey, Working on it! I think it might be the name I put on the pixs. I used a parentheses. ( ) I'm re-loading them with a different name. jBob, I found the problem! I named the pictures with a ( ) like:
critter(1) critter(2) etc.lesson learned!
problem fixed!
j
Great, glad to help!
(smiley captioned for the humor imparied)
Yea, the ()s and various other special characters bugger up the URL-to-image code… probably should fix that sometime…
And you can’t put them in a file, and paste from the file.
All you get is red "x"s where the pix was. I had to pull them back out of the file “critter” and just list them in the parent directory…
sheeeesh…
j
John Bouck said:Sheesh John!
And you can't put them in a file, and paste from the file. All you get is red "x"s where the pix was. I had to pull them back out of the file "critter" and just list them in the parent directory..... sheeeesh...... j
You’re still battling that 'puter??!
BTW what I do on file naming is use underscore (_) instead of brackets or spaces. Works without fail on any of the browsers I’ve come across.
On that “not in the file”, that’s probably because the SW expects the stuff to be in the parent directory and doesn’t know you created a sub dir.
