Greg Elmassian said:
Well, using JMRI saves Graeme the trouble of programming the layout display and the toolkit for drawing the layout… so interfacing to JMRI will save time… and you can run JMRI on small cheap processors…
So interfacing the sensors to JMRI… it would be nice to do some kind of ultra low power bluetooth, that stays in a deep sleep until woken by an event. So your sensors would be battery powered.
I assume you would prefer wireless over hard-wiring the sensors? I suppose you could also do an RS485 loop, very little traffic… you have wires, but you would be working in multi-drop so only one “bus”…
You are spot on with why I am looking at JMRI.
I was thinking hard wired to the Pi’s GPIO pins then Pi driving the JMRI for a display.
I still have to make up my mind whether to build the layout outside or inside.
Outside I have heaps of room about 40-50 squares Metres, while indoors I am limited to 7.5Metresx 6Metres.
Outside most likely wireless but indoors could be hard wired. The outside would be run off a SLA battery with a solar trickle charger connected (in the sub tropics plenty of sun).
I could use a Pi zero W connected to another one to make a stand alone network. Hmm plenty of food for thought with both ideas keep them coming.
