I have several Piko buildings to put together and using the UHU glue that comes with the kits is sometimes messy.
I was wondering what methods some of you used when putting the clear glass in the frames of windows and doors that will prevent the glue from oozing out and distorting the glass, getting finger marks on the glass, and preventing the fine glue hairs when applying the glue?
Cutting the clear sheet plastic is not a problem just the injected window glass insert and the glue application method.
I need help.
