Picture Posting with just a 'paste' ctrl-V
I was slightly amazed to discover I could insert a photo copied from West Marine in a thread just be pasting it, using CTL-V.
http://www.largescalecentral.com/forums/topic/28092/-/view/post_id/360695
Let’s try that again. Wow. It works. That makes it easy to post pics.
Which OS?
I have never been able to cut and paste from my Mac or iPad. They both use the newest IOS.
It seems to me a picture needs to be on a server somewhere accessible with established URL, so you can’t expect to directly copy / paste from your phone or computer.
-Ted
You are correct Ted.
Pete,
You are not actually “inserting a copied photo” into the message. You are actually just Inserting a link to the photo.
The 2 above reside at:
http://www.guidetozscale.com/assets/images/duplex.jpg
http://www.trainweb.org/willstrainart/Train_Art_files/AutoCad_Title.gif
If someone deletes them from guidetozscale or trainweb they will no longer show here.
I generally have down loaded photos to my computer then upload them to my album, then copy the link but i did take a shortcut and posted a link from my google photos album…it worked! (https://photos.app.goo.gl/iWHYyRAonIQZPnrJ3)well it worked from my computer…not so much from the tablet.
What browser are you using Pete ?
-Ted
Yes Ted that is correct
Value is required blah blah blah
Never mind…
Here’s a photo from my computer - which doesn’t work. I had figured it was the URL that was allowing me to post it.
The point is you don’t have to go thru the “Manage Photos” or “copy image location/Insert photo” just to paste a photo. Just copy it and ctl-v.
(I’m on Win10 with Firefox, but I don’t think it’s a browser issue. It’s the forum software extracting the URL and doing the ‘insert image’ for you.)
I asked about OS, because Benevolent Bob once posted key equivalents to mouse controls… and it looked similar.
My nonsense post above was trying to insert a pic using the Reply tab at the top of the thread. I get instructions that says I can insert from the HD, but it didn’t work 2 ways I tried…
OMG, it works!
Image result for Steam locos
It’s not a fluke. It DOES work if the photo is already on line somewhere. Good find Pete.
I found a peculiarity. I tried ‘pasting’ a photo from my Freight Shed space, and it worked - sorta. The pic turned up but it was a bit large, so I clicked it and hit the “insert/edit image” button on the toolbar, and found no dimension data - nor would the s/w fill in any. To resize, I had to go back and insert it using the insert/edit image and then set the dimensions.
Test
I tried it this morning and got a page of code that was harder to delete, took several clicks to undo it … somehow the old way was better!
I’ve been holding off on commenting.
When you right click on a picture and your browser gives you options like copy picture, copy picture location, etc. then you KNOW what you are getting.
When you find a “shortcut” like just says “copy” and “paste” without being specific and it works, that’s great, EXCEPT that this often changes from operating system to operating system, or changes with different browser versions, etc.
I’ve seen these shortcuts come and go since I started using computers in 1975…
I’ve always been an advocate of knowing what is happening, rather than leaving it to the whims of the computer gods…
I have a lot of “friends” that ask for help on computers, and overwhelmingly they are in 2 camps: the most common is “I don’t want to know how it works, just tell me the keystrokes and I’ll memorize them or write it down”… this camp will be back every month or so asking how to go an almost identical task, because they don’t want to spend the time understanding the concept.
The other camp, with many fewer “occupants” are the ones that take the time for the explanation of how something works, and can do similar tasks all on their own.
Guess which camp get’s the fastest “service” from me…
I liken this thread to the first camp… a new “shortcut” is found… and in a month or so, if it quits working, many people are back to square one… did everyone come out ahead?
And knowing is better.
Yup. It even happens with technicians. They want the quick fix, instead of taking the time to understand the why.
I am in that camp. But, surprisingly, the “experts” I talk to, tend to give a long sigh before they go through the explanation. Almost like they don’t want to be bothered passing along a nugget of knowledge.
Greg, some of us will come out ahead. Its called “entertainment”.
