Would like to replace the 6 volt batteries with capacitors on my Phoenix sound systems,
anyone know what I need?
Thanks
Don
Thanks
Don
If you run battery power, you can run fused battery power directly from your BIK. You shouldn’t need any capacitors.
If you use track power, capacitors might be the way to go, but someone else will have to help you.
I would look into Super caps, 6 volts would only use 3 in series plus a 6 volt regulator to charge them. The ones in all my older LGB engines have been working for 10 years.
